LS3 ASA 12480110 Cam Card specs
Scroll down to all most the bottom of the page. It's the 2nd from the bottom set of specs.
http://www.superchevy.com/technical/...e/viewall.html
So what does your paperwork say?
Yeah the ASA is suppose to be a 226/236 110lsa, but specs on the link says 224/235 110+3 @ .05" lift. I'm sure the 224/235 is a error, but I'm not sure whether the 107 ICL is correct or not.
Cam Lift: .525” Intake / .525” exhaust
Cam Duration @ .050”: 226 deg. Intake / 236 deg. Exhaust
Lobe Separation: 110 Degree
Crane used the grind the hotcam, asa cam, and grand am cup cam for GM...when Crane went out of business, GM got someone else to grind them. Cams like the GM847 LT1 cam are still around, just have a different part number now. The hotcam, asa cam, a GA cup cam or showroom stock cam as it is also known, have been around since LS1's cam out...if there is any change to the specs, its because the new company grinding the cams is using there own lobes and got them as close to the original specs as they could.
I don't know enough cams to make an educated decision, but if two cams are said to be "the same" how close would the cam cards be?
Here is the Howard Cams ASA cam card:
I am open to suggestions from people that know better. The new Holley software allows a very detailed configuration of the Injector Phase Angle. In order to populate this table the information on the cam card is needed.
I have the GM ASA cam, but so far I have yet to find a cam card for that cam. The Howard Cams ASA cam is said to have "advanced lobes" for more power.
Having said all that and for the purposes that I need, will the Howard Cams ASA card be "close enough?"
Andrew
Andrew
