LS2 with LS1 oil pan
I'm installing a LS2 in a 67 camaro and it looks like the LS1 oil pan will allow for more clearance. Will I run into any problems using the LS1 pan?
It it happens to be an LS2 from a GTO be sure to knock out the freeze plug that blocks off the dipstick hole in the block while the pan is off as the GTO pan uses a dipstick that goes into the pan.
