Ls3/l92 cam
Ls3/l92 cam
Is anyone running the lpe gt11 cam wanna no what kind of track times and dyno numbers. Or if anyone is running a sleeper cam I would like to no
Most people don't run LPE cams because they are meant more the driveability side and not extract the most HP out of a setup. Plus, those cams are older grinds that have been out for awhile and lobe technology has changed since then.
I would take a look at Geoff's cams since it uses his lobes which are easy on valvetrain and make good power
http://www.engpwrsys.com/index.php?a...&productId=109
