Ls3 416 gto
Old 06-07-2013, 04:49 PM
jdub38672's Avatar
Default Ls3 416 gto
Hey guys!! Figure I'd post my first build. Parts are coming in everyday. I'm getting rid of the LS1 and moving on to bigger and better things. LS3 block bored 4.070 to make 416 cubic inches of a tire shredding torque monster. Mahle forged pistons, Eagle 4.000" stroke crank, Eagle 6.200" rods with ARP2000 bolts, ARP head studs to keep everything in tact. I have plans on eventually using a 200 shot of the giggly. Kooks 1 7/8 long tubes to be connected to a full 3 inch exhaust. Currently working on cam specs, it's going to be huge!! With a LS3 style car intake I'm hoping to make 550rwhp on 11.25:1 compression with a 6 speed. To be continued....
Attached Thumbnails Ls3 416 gto-armored-crank.jpg   Ls3 416 gto-combustion-chamber.jpg   Ls3 416 gto-exhaust-port.jpg   Ls3 416 gto-bolts-block.jpg   Ls3 416 gto-intake-manifold.jpg
Old 06-07-2013, 04:51 PM
jdub38672's Avatar
yes, i'm aiming for 550rwhp naturally aspirated through a 6 speed
Old 06-07-2013, 04:59 PM
jdub38672's Avatar
Default Few more pics
more goodies
Old 06-07-2013, 07:36 PM
Jimbo1367's Avatar
Make sure you buy all parts(including pistons) BEFORE YOU GET the block bored and honed. Make sure you also go wild cam specs with very aggressive ramps and HD/solid/SS valves so they will take the high rpms. I think some YT 1.8s would be killer too.
Old 06-08-2013, 06:34 AM
litle88's Avatar
Make sure you buy all parts(including pistons) BEFORE YOU GET the block bored and honed. Make sure you also go wild cam specs with very aggressive ramps and HD/soid/SS valves so they will take the high rpms. I think some YT 1.8s would be killer too.
Aggressive ramp rates and YT 1.8's do not go hand in hand! Why would you say 1.8's?
OP you have a nice build BUT I'd call Brian Tooley and get a cam specd out to your needs, you can do that and get his cam package with his Platinum springs.
Old 06-08-2013, 07:08 AM
jdub38672's Avatar
Thanks for the advise I'm a little further in the build than my post reflect. The rotating assembly I purchased is balanced and double checked. I went with LS3 rockers with the comp trunion upgrade. Lunati double springs have been purchased as well. Now for pistons I picked a Mahle 2618 forged piston that will be nitrous friendly in the future. The block has been bored as well to the specs of the pistons.
Attached Thumbnails Ls3 416 gto-ls3-block-3.jpg   Ls3 416 gto-piston-1.jpg   Ls3 416 gto-piston-bottom.jpg   Ls3 416 gto-valvetrain-3.jpg
Old 06-08-2013, 09:05 AM
87silverbullet's Avatar
You do not need to go wild with the cam to make good power with a 416 LS3 headed setup. Lightweight valves such as the LS3's would be a good choice to help in valvetrain stability.
One question, why did you go with a 6.200 rod? That takes away from the compression height of the piston and in turn makes it not a good thing to run nitrous on. I'm not saying you can't but you would have to watch your tune and be conservative on it with spraying nitrous on a piston with a shorter compression height.
Old 06-08-2013, 11:51 AM
jdub38672's Avatar
Just personal preference, I like to put the longest rod I can in my motors within reason. Using the 6.200 rod still leaves a decent compression height on the pistons. I also chose a 2618 piston vs. 4032 material to compenstate for the etra heat from the nitrous I plan on using. Not quite sure on the valves I'm using, they are stock valves that come in LSA heads. I will post a pic of my assembled heads later today. Keep in mind the most spray my setup will see will be 200 or less.
Old 06-08-2013, 12:10 PM
For only a 200 the piston material is not going to really matter because you are not going to make enough heat to damage either one. You would want to worry more about the wrist pin getting up into the ring pack with that longer rod. Nitrous and ring lands up higher than normal are not a good combination. Just keep that in mind when tuning it on the bottle.
Old 06-08-2013, 10:12 PM
jdub38672's Avatar
I will keep that in mind and make sure the tune is spot on. Planning on running a few thousands miles before the nitrous. Hopefully if it makes 500-500 rwhp should be plenty fun for a little while.
Old 06-09-2013, 08:38 AM
jdub38672's Avatar
Default Progress!!!
Trunion upgrade complete and heads are assembled.
Old 06-09-2013, 08:40 AM
jdub38672's Avatar
Trunion stuff
Old 06-09-2013, 02:19 PM
litle88's Avatar
Looking good bud!
Old 06-09-2013, 03:31 PM
jdub38672's Avatar
Originally Posted by litle88
Looking good bud!
Thanks man! I'm hoping to make some good power like your build. However my compression is going to lower which I know will kill power. I bet your car is a total beast on the street? Is first gear even useful?
Old 06-09-2013, 05:58 PM
litle88's Avatar
Lol it's useful due to the cam bucking a Lil but I can careless about that. The 4.11's help with that. I wish I could have gone with a bigger cam, the cubes suck it all up. It is a blast to drive bud. I hope you meet your goals, it's not too late to make a few adjustments if you'd like before you have regrets later bud. If your happy with it it's all good bud. In for the results that's for sure.
Old 06-09-2013, 06:25 PM
keith102371's Avatar
Have you decided on your cam yet?
Old 06-09-2013, 07:25 PM
jdub38672's Avatar
Yeah I agree with you not too worried about the cam bucking a little. Having a 6 speed helps in the area. Probably going to keep my stock gearing for now.
Old 06-09-2013, 07:28 PM
jdub38672's Avatar
I have several ideas just haven't narrowed it down yet. Hopefully I will have my mind made up by this week. Planning on building the short block next week. Melling high volume pump, ls7 lifters, timing chain, and tensioner are in boxes ready to go. I will post pics of those tomorrow. All I can tell you is the cam is going to be huge!! I will let you know specs soon.
Old 06-10-2013, 04:33 PM
jdub38672's Avatar
Default Camshaft selection
Camshaft is going to be in the ball park of 247/263 on 114
Old 06-10-2013, 04:59 PM
jdub38672's Avatar
Default More parts
Ls2 front cover, LS7 lifters, oil pump, corvette timing chain tensioner. It's like Christmas in June.
Quick Reply: Ls3 416 gto
