Every engine builder should have one of these
Old 06-12-2013, 12:43 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Default Every engine builder should have one of these
AlignIt Tools are used to align the Rear Main and Timing Covers and install the seals!
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 and all GM v8's from 1997-2013 Timing and Rear Main cover and seals. Works with all LS based engines!
Here is a couple simple but very effective tools to help you make easy work of aligning your Timing and Rear Main Covers. CNC Machined to exact tolerances, the AlignIt tools
get the covers centered perfectly with the crank. The O-ring design makes for a perfect snug fit no matter the temperature that can cause expansion/contraction of engine covers, crank & tools
that will hinder a perfect fit. The O ring design eliminates this problem. After the covers are centered and torqued down, use the AlignIt Tools to install the seals in seconds!
Available in the Pro Series 6061 Aluminum Anodized and the standard PVC Plastic. Both are CNC Machined to exact specs
from Billet materials.
www.saccitycorvette.com/AlignItTools.html
If you're doing a Rear Main Seal or Engine Build, its a good time to start keeping unfiltered oil out of your bearings and lifters! Check these Billet Oil System Improvement parts out!
https://www.saccitycorvette.com/OilS...provement.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 06-12-2013, 10:30 PM
tonytone4143's Avatar
nice tool here
Old 06-12-2013, 10:35 PM
LS1Tech Sponsor
Thanks Tony!
__________________
Old 06-13-2013, 05:36 AM
litle88's Avatar
Oh damn that's nice saccity!
Old 06-13-2013, 06:17 AM
Kamaro's Avatar
Nice!, I just ordered mine.
Old 06-13-2013, 11:09 AM
LS1Tech Sponsor
Thank you for your business Kamaro, we really appreciate it! We'll get it right out to you!
And Thanks for the compliment litle88!
__________________
Old 06-13-2013, 11:37 AM
newschool72's Avatar
Cool tool ! If I ever need to pull the cover again, I will get with ya. Do you ship quick?
Old 06-13-2013, 12:42 PM
allan808's Avatar
You got a tool that works with seals already installed?
Old 06-13-2013, 03:56 PM
LS1Tech Sponsor
Sorry Allan, we don't.
The problem we found is by using the seal to align the cover is that the seal is soft and will not hold the cover exactly center with the crank, especially if the pan is off. Our AlignIt tool fits solid on the crank and into the cover for a mistake free install. Then the seal is installed using the AlignIt tool to keep the seal from getting cocked or distorted. The AlignIt just helps make it easier and with no chance of misalignment that can cause a leak. Plus it fits nicely in the tool box.
__________________
Old 06-13-2013, 07:06 PM
JS01's Avatar
Take a balancer you dont care about and hone the ID just enough to slip over the snout, tada. This is how most machine shops, and the one I previously worked at did it. Done 100's of engines this way.
Old 06-14-2013, 12:15 PM
LS1Tech Sponsor
Hi allan808,
We do have a Hub Simulator tool. Its not as accurate as the AlignIt Tool because the seal flex's. It works the same as using your hub to line it up.
You can find it here.
http://www.saccitycorvette.com/Timin...nmenttool.html
Thanks
Christian
__________________
Old 06-14-2013, 12:23 PM
Jimbo1367's Avatar
Saccityvette,
I was weary once I started watching the video, as I didn't think installing the seal was that easy. I always figure it should be off the engine and something supporting the back side of it during install. Looks like a good tool!!!
Old 06-14-2013, 12:31 PM
Super Hulk Smash
JakeFusion's Avatar
Wow that's nice. I may have to pick one of those up.
Old 06-14-2013, 02:40 PM
ducatisl's Avatar
Just ordered. Looks good.
Old 06-14-2013, 03:59 PM
3rdCoastPowerSports's Avatar
why not just use the correct Kent Moore Tools?
Old 06-15-2013, 04:22 AM
Jimbo1367's Avatar
probably cause the Kent-Moore one cost much more. Also........ Kent Moore isn't a vendor.
Old 06-15-2013, 04:31 PM
LS1Tech Sponsor
Thank you ducatisl, we really appreciate it!
__________________
Old 06-15-2013, 09:53 PM
TTA1437's Avatar
Just placed my order.
Old 06-19-2013, 04:46 PM
LS1Tech Sponsor
Thank your TTA1437 for your business!
__________________
Old 06-21-2013, 07:31 AM
maroonls1z's Avatar
If you already have the rear cover off couldnt you put the seal in the cover and use the plastic ring to line everything up? what would be the benefit of this over that? Real question, not trying to doubt what looks like a good product. Also i thought you were suppose to put the seal on without lube because they come prelubed
Quick Reply: Every engine builder should have one of these
