Swap a ls2 for a ls3
Old 06-30-2013, 05:28 PM
Gene Brown's Avatar
Default Swap a ls2 for a ls3
Have a Trailblazer with a blown LS2 motor. Has anyone replace theres with a LS3?
Old 06-30-2013, 06:40 PM
BODUKE's Avatar
I have heard of a ls3 swap in a trailblazer ss. Its not a difficult swap.
Old 07-01-2013, 05:07 AM
litle88's Avatar
Do it it's not hard!
Old 08-30-2018, 01:08 PM
Received 3,021 Likes on 2,352 Posts
Resurrecting this! Toying with the idea of getting a Trailblazer with 5.3 and swapping it for an LS3/L99 or truck 6.2L. Mechanically sounds straightforward, but what must be done electrically? Do all sensors hook up the same? Can I use the same ECU, BUT reprogrammed/retuned?
If this should be in the Conversion section, would a Mod move it please?
Old 08-30-2018, 02:17 PM
Received 3,361 Likes on 2,079 Posts
‘What year is the Trailblazer G?
Old 08-30-2018, 02:18 PM
84FSP's Avatar
The model year split was 06 I believe where they changed from 24k reductor to 58k reductor. The LS3 is 58K so it would reduce the number of other changes you need to make, I think mostly sensors and wiring.
Old 08-30-2018, 02:46 PM
Just dreaming this up; don't even have a vehicle, but there are some around here, so it got me to thinking. Looks like I better stick to later ones to keep the electrics simpler. It was mainly the differences between the 5.3 vs. LS3/L99 that had to be accounted for. The same could be asked if I were to get a late 5.3 Colorado/Canyon. I thought all these were Gen IV. Looks like some are Gen III
Old 08-30-2018, 03:59 PM
Yeah, swapping a gen4 into a gen4 is pretty much a plug and play, minus the tune. If you could grab the ECM from the donor, no tune needed.
Old 08-30-2018, 06:53 PM
Do TB's and Camaros use the same type ECM?
Unless the TB one is vehicle specific, then copy the tune over... if that's possible.
Old 08-30-2018, 10:17 PM
Not sure. I’ve messed with more aftermarket ecm’s than GM stuff.
Old 08-31-2018, 12:42 AM
hot98z28's Avatar
they dont camaros are newer and from what ive heard the ecu is better for tuning but if gen 4 to gen 4 its a plug and play. maybe knock sensor extension, and cam sensor relocation extension if similar to truck 6.0 set up.
Quick Reply: Swap a ls2 for a ls3
