valve spring mic need help,pic inside
Sawzall and Welder Mod
Take a caliper and verify, but on mine, the correct reading is across the true flat top of the mic, measured as if you were to put the mic in a vise or measure it with a vernier caliper. If the retainer is too small and is dropping in the step, try and catch the edge of the retainer with the top of the mic
1.832 ..... The 1 is a given. The 8 is the highest number you can read on the vertical number scale. The 32 comes from the point where the vertical line intersects the rotating barrel. Put it all together and you get 1.832
BUT you should be measuring from the top of the mic to the bottom of the retainer. It looks like the retainer is slightly sitting down in the mic and not squarely on the outer rim. Loosen it up and shift it so the retainer isn't perfectly centered on the mic, more offset. I bet you get a different number
And yes, if you are measuring too big of a number, you would shim to bring the measurement down. DONT measure one cylinder and assume the same shims will work for all the springs. Measure them all before and after the shims have been installed
Tolerance is going to depend on what you are doing with your engine. .005 difference in installed height makes a bigger difference on 600in/lb springs in a 8500 rpm motor, but not so much on 200 in/lb springs in something that only sees 5k rpm.
For what its worth, you aren't given a whole lot of options. Most shims come in .015, .030 and .060 increments. So without altering the valve seat depth you wont have a ton of options. The last heads I setup were all within .005 -.007 of each other and I was OK with that. Theoretically on my springs that would be about 4lb variance in installed seat pressure. Realistically you aren't ever going to get a spring kit out of the box that doesn't have at least that much variance in the springs to start with.
If you have a valve spring pressure tester you can match the lowest pressure springs with the tighter installed heights and the higher pressure springs with the looser tolerance installed heights to help equalize things. This is getting pretty **** though and wouldn't expect anyone to actually do this unless you are building a VERY serious race engine
