Lifter Trays and Lunati High Rev Lifters?
I have been searching around but still havent found anything concrete, but can anyone tell me if the lifter trays are deleted with link bar lifters? I am building an LSA engine and I know that my old LS6 lifter trays wont even fit in the block but if the trays are not even used, then I wont have to worry about buying the LSA trays.
Thanks in advance for the advice.
I asked because you did know that you can't run an oil heavier than 5w40 with those lifters?
I have heard more than a few times that the tolerance is real tight on these lifters and I was informed by another member about the oil to be used.
Scroll down on the link to thwe part# 5294
http://johncalliesinc.com/morel_products.php
Lunati's are rebadged Morels.
http://forums.corvetteforum.com/c5-t...-link-bar.html
Thanks, I didn't know about the oil. I guess I will be running 5w40 then. Just as well I suppose, my main and rod bearings are a bit tight anyway from using ARP main studs and ARP 2000 rod bolts, and that's even with undersized bearings.
