short travel lifter question
Old 08-02-2013, 11:55 AM
ws6guy27's Avatar
Default short travel lifter question
Looking use a set of short travel lifters.. wouod they be good for street driving or is it mostly for dray. I know the short travels are the middle man of hyd and solid lifter. Best of both worlds.. but I dnt want anythjng fn up on the street
Old 08-02-2013, 12:06 PM
lil john's Avatar
Few out of 10,000 the guy's who have had problems are few.......But to be 1 of those few???? problems will occur.They have a lot of great short travel lifters Morel, Johnson ,Lunati......There are few with problems but for the masses......They do work great.
Old 08-02-2013, 01:10 PM
ws6guy27's Avatar
Ok good to hear. Just ordered a set from comp. Now im n3eding a good durable rocker set up lol 1.8 ratio blah!
Old 08-02-2013, 02:32 PM
Super Hulk Smash
JakeFusion's Avatar
Just get the preload right. And that means checking every single valve. Because you only have .058" worth of travel. If you're off .025" the wrong way, you will have issues.
Old 08-02-2013, 02:47 PM
ws6guy27's Avatar
Well **** lol. Checking every single one.. they should all be the same...
Old 08-02-2013, 02:50 PM
Super Hulk Smash
JakeFusion's Avatar
Ha. Ha. Ha.
No.
You'd be surprised how far everything is off in these motors, piston to piston. Valve to valve. It's crazy.
Old 08-02-2013, 04:02 PM
ws6guy27's Avatar
Whats the difference in the comp short travel or the johnson short travel?? Price diff... quality..ect
Old 08-02-2013, 04:07 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
I've used and sold both with good results.....if you already ordered the Comp's I wouldn't worry about them.
As Jake mentioned though.....be prepared to check every one if you want to do this correctly. That will assure you get the best results from the install. There are lots of variables/stacking of tolerances to account for (cam base circles, valve job depth, valve margin thickness, valve overall length, rocker arm variances in cup depth, etc.).
ALL of this effects the amount of preload in the system and your window for error in pushrod length is much more narrow. A standard lifter, LS7 lifter, etc. has close to .200 plunger travel offering a much larger window of error but of course doesn't offer the performance advantage a well made limited travel lifter will off you.
-Tony
Old 08-02-2013, 04:10 PM
ws6guy27's Avatar
Old 08-02-2013, 04:11 PM
ws6guy27's Avatar
As Jake mentioned though.....prepared to check every one if you want to do this correctly. That will assure you get the best results from the install.
-Tony
Thanks tony. I rhought they would be a good choice. Just wanting to try them out. Want to do everything once amd leave it.
Old 08-02-2013, 05:08 PM
maroonls1z's Avatar
what is the best way to check PTV clearance with the short travels?
Old 08-02-2013, 05:33 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
I believe the morel's and lunati's are one and the same. does Johnson make the lifter for comp?
Old 08-02-2013, 06:29 PM
Super Hulk Smash
JakeFusion's Avatar
I don't know, but the Johnson's are damn fine pieces.
Old 08-04-2013, 04:23 AM
Flow Wizard
They make alot of OEM and aftermarket stuff for various companies (including GM) but I know for a fact the Comp limited travel supplier/builder is not Johnson.
I think they are both good pieces (and literally have ran both in personal builds and my customer's builds)....the more expensive Johnson short travel has the pressurized axle oiling which is a nice perk but to be fair they are higher priced than the Comp so it makes sense.
OP....PM me if you need more info etc.
-Tony
Old 08-04-2013, 06:37 PM
ws6guy27's Avatar
pm sent
Old 08-07-2013, 04:36 AM
ws6guy27's Avatar
Well got the short travels in made by comp. Is anyone running these csn tell me how they installed and checked pr length correctly? Since only has .058 window. I dont want to have issues. I want to do this correctly
Old 08-07-2013, 11:49 AM
maroonls1z's Avatar
im curious to the best way to check piston to valve with the short travels as well
Quick Reply: short travel lifter question
