RPM limit on this rotating assembly question
WHat do you guys think the RPM limit would be for this engine, based on the rotating assembly alone. AS in, when would you start to get scared it may fly apart.
Stock LS3 crank
Manley platinum series flat top pistons
6.300 lunati voodoo h beams with 2000 arp bolts
King bearings and Childs & akerly rings
all new machinework and balancing etc.
Im thinking it should be able to take 8,000 all day long.
Obviosly I know cam/valve train is going to play a huge part, but I want to know what the botoom end can take on a regular basis.
Stock LS3 crank
I posted this question on a Gto forum (not ls1gto) I had some complete idiots trying to tell me anything over 7,200 and it's going to toss rods out the side. I've seen stock rods with rod bolts handle 7,500 with no issue, so I just deleted my post instead of wasting my time with those "Internet engine builders" , no reason a long rod motir with quality internals can't live @7,500 or even 8,000
I know this isnt apples to apples but there are guys running $400 bone stock, junkyard 5.3's in demo derbys turning them 7500 a half hour at a time. I think you do not need to worry about turning a forged aftermarket rods/pistons to 8k or a little more.
