hp rating on gmpp 4.125 crank?
anybody now the max horsepower I can safely make on a gmpp 4.125 crank?
engine started off as a gmpp crate 454lsx
I upgraded a couple parts
here is the specs
gmpp 4.125 forged steel crank
compstar 6.125 rods with arp2000 bolts
cp custom 4.210 bore 11.5 to 1 compression pistons
ARP main studs
ls7 6 bolt heads aftermarket cnc ported and polished
ARP pro series head studs
stock ls7 rockers 1.8
cometic head gaskets
holley hi ram ls7
holley tb
160# injectors
obx turbo headers
s475 1.32 ar t6 turbo (will be upgraded later)
I know the turbo is small for this build but I only want 1000rwhp
and I will be running q16 or e85 and meth injection.
this is going in my 69 Camaro with a th400 and 9" outback
any input would be appreciated.
here is the specs
ARP main studs
holley hi ram ls7
holley tb
160# injectors
obx turbo headers
Really dont have much knowledge on those cranks but I think it will meet your goals or at least you will be close to the rating. I would say 950-100+HP... Then again idk much about those cranks or how durable are they. Hopefully someone more knowledgeable will come in and help you.
