404 ls stroker pistons wont clear reluctor wheel
Having trouble putting a 404 stroker together. The pistons are ross racing pistons. After making a few calls they said that three off the pistons are different for clearance. I found the three pistons that are slightly different and installed them in the number 8 cylinder to check and see if they would clear the reluctor. All of the pistons that i have tried are still hitting the reluctor wheel. Its a manley 4.00" crank and manley h beam 6.125" rods. Anybody run into a similar issue?
Thanks,
Pete
Thanks,
Pete
