Dart LSNext blocks have arrived
Old 08-30-2013, 11:00 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Default Dart LSNext blocks have arrived
We have received a large shipment of the newest LS block available. This is the Dart Machinery LSNext block. We have not yet started a build with one of these, but we are excited to get to work on one soon.
Here are some pictures of one that's in stock here, as well as some highlights from Dart. At the bottom you'll find part numbers and pricing. We don't yet have more oil pan spacers or block completion kits in stock for pictures, as we have shipped what we received to customers already. I will come back and update with those as soon as we get the next shipment.
Dart’s LS Next block is the first significant change in the architecture of the LS engine platform. By eliminating the “Y-block” design and utilizing conventional style main caps and oil pans, Dart has addressed the problems resulting from the LS engine’s separated crankcase bays. Windage is greatly reduced, resulting in increased power along with a much stronger main web area.
Features:
Dart’s LS Next block is cast in the USA with premium cast iron alloy
Conventional style 4-bolt steel main caps with 7/16” bolts are used
Full main webbing for maximum bottom end strength
Cylinder barrels are extended by .375” at the bottom, providing greater piston support for all combinations
9.240” deck height, with options of 9.450" are available which allows for a possible effective barrel length of 9.825” deck block
Extra thick Siamese cylinder bores allow for large displacement capacity, and a max bore size of at least 4.200”
A 5/8” thick full deck design with a 9.240” deck height
Six head bolts per cylinder provide secure clamping for power adder applications
Head bolts are upgraded to 7/16” for increased strength
Blind head bolt holes don’t go through into the water jacket
Provision for oil restrictors in the lifter valley • Revised low restriction priority main oiling system
Pro-Stock / Pro-Mod big block style stepped main oil galley
An external oil filter must be used with stock or aftermarket oil pumps
Dual starter mounts
The water jacket on the #1 cylinder has been expanded for additional cooling capacity
LSX style lifter bosses and dog bone provision are provided
You'll notice some "odd" differences from what you're used to. Older SBC guys won't find most of this odd and will recognize some things. You might also have some questions, which are quite welcome.
You'll notice the different cam retainer plate
Water jackets are revised.
You aren't running stock lifter guides in this block. LSX guides or tire bars.
These have press in freeze plugs.
The barbell hole is plugged.
This will use stock front and rear covers.
We know how the stock block and parts handled all of the passages under the covers. We will have to get the completion kit in here to see what Dart does in those areas. Especially with the deletion of the stock cam retainer that connected the two front oil passages.
There is no provision for a Gen 3 cam sensor. You will have to run the Gen IV front cover and sensor.
There is no passage that supplies oil to the stock location in the valley cover for the oil pressure sensor. There might be a passage you could drill into, we are not certain at this time. You may have to run the sensor in an alternate location.
Note the pads for a starter on either side of the block.
Block with 4.100 bore = Dart 31837111 $2469.95 with free shipping
Block with 4.125 bore = Dart 31837211 $2469.95 with free shipping
Block completion kit = Dart 32000016 $129.95
Oil pan rail adapters = Dart 62230001 $329.95
Moroso LSNext oil pan = 20144 $534.99
Required pickup tube for that pan = 24144 $129.95
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 08-31-2013, 07:46 PM
Bill00Formula's Avatar
They look awesome. So does that pan work with 4th gen f-bodies? Will there be a cheaper oil pan in the near future?
Old 08-31-2013, 08:15 PM
SS67SS's Avatar
I got a big grin when I saw it has splayed 4-bold mains. Retro block..
This should be nice for those building north of 1000hp. However, this block "looks" really heavy (more than LSX). Any info on this?
Old 08-31-2013, 09:42 PM
KCS
Moderator
KCS's Avatar
Can't wait to see these things in some serious NA builds. Are they legal in NMCA?
Old 09-01-2013, 08:26 AM
studderin's Avatar
looks like the lifter might fit thu the valley? anyone know?
Old 09-01-2013, 10:32 AM
It weighs 227 pounds.
I can drop a head on one and try to get some lifters through the window after LSFest.
For an fbody you'd want a stock pan with the rail adapters.
__________________
Old 09-02-2013, 05:32 PM
Blackpanther99's Avatar
Love how you can change out the springs without taking out the heads
Old 09-03-2013, 12:04 PM
So to install this block in a 4th generation f-body that already has an LS2/LS3/LS7 (or known differences) you only need the oil pan adapter, maybe different rockers (so the standard morrels don't work?), and need to wait for someone to come out with some sort of provision for the oil pressure sending unit? I currently have a motor with an LS7 block and was sort of thinking about getting this block.
Old 09-13-2013, 10:11 PM
TurbopigB4C's Avatar
When the tall deck block comes out what stroke will this accommodate on a street engine?
Old 09-20-2013, 06:42 PM
GR8GAME's Avatar
I'm waiting for the aluminum version.
Old 09-20-2013, 08:38 PM
I doubt Dart will even consider aluminum being historically more for drag racing than anything else.
You can get an RHS aluminum tall deck for 3900 on a non sponsor.
Old 09-20-2013, 10:27 PM
flash911's Avatar
There was a press release:
http://www.dartheads.com/dart-news/l...k-coming-soon/
Old 09-20-2013, 10:30 PM
I sell RHS blocks, and I'll match any price.
__________________
Old 09-21-2013, 11:42 AM
The Dart aluminum will be pretty nice for building a standard deck 454 aluminum as long as they can make their price point more competitive than the RHS tall deck aluminum out now and comparable to the price of Darton sleeving + used 5.3 4th gen block.
Old 09-23-2013, 02:59 PM
214Chevelle's Avatar
I'll be getting an RHS block really soon. What do you get for one? I want the standard deck, 4.120 unfinished one that's ready to hone.
Old 09-25-2013, 12:28 PM
helicoil's Avatar
Any ETA on the tall deck blocks?
Old 10-16-2013, 01:39 AM
Jontall's Avatar
You called COMP and ratted the guy-out for selling the block for $3900 and now no-one can get it. I hope that you are giving everyone the $3900 price match on the RHS LS Block.
Old 10-16-2013, 08:31 AM
Actually I didn't, so I'd appreciate it if you'd consider having a little more class and making sure you know what you're saying before posting such accusations. I've not talked to Comp at all about pricing on these blocks. No one even named the non-sponsor beyond that exact title and I have no idea who it was.
__________________
Quick Reply: Dart LSNext blocks have arrived
