LS3 top end swap build thread
Old 09-03-2013, 09:16 PM
mklaus1's Avatar
Default LS3 top end swap build thread
Ok this is not my first build, I blew the original LS1 motor when the oil pump failed, cracked the block around the crank snout. I swapped an LS2 and an LS6 intake with a 226/230 .598/.601 111 +4 and longtubes in its place. Tuned the car using HP tuners. Never had the car on a dyno but track times were best of 12.6 best mph was 113. Best 60ft was 2.09. So, fast forward a few months and I have decided to swap the LS3 heads and intake onto the stock LS2 bottom. This time I decided to take pictures and make a build thread. Hopefully this is in the right section, if not please move to the correct place. My car is a 98 NBM Trans AM that needs a paint job and wheels REALLY bad. So to start the build I used a very good step by step write up I found on this site for dropping the engine out of the bottom. When I pulled the LS1 and set the LS2 I did it through the top and I can tell you for me out the bottom is exponentially easier! Ok so I am just going to post a few pics of the progress, I am still waiting for the LS3 parts, we are doing a trade.
Old 09-03-2013, 09:32 PM
mklaus1's Avatar
Before I got started
Main VCM connectors unplugged and moved
PCM out of the car
Old 09-03-2013, 09:41 PM
mklaus1's Avatar
A\C Parts
Engine and Trans Out!
Another one of the engine and trans out
Old 09-03-2013, 09:47 PM
mklaus1's Avatar
Well according to the directions, this was one of the most important steps!
The wife was not to be outdone!
My dad who helped get the motor and trans out!
Old 09-03-2013, 09:59 PM
mklaus1's Avatar
Heads off!
Head Valve Side
A little carbon on the pistons!
Old 09-03-2013, 10:13 PM
mklaus1's Avatar
Cleanup started
All Cleaned up!
I had to take a break during my project to take my little helper to find a friend. He loves frogs and this is the biggest one we have caught so far. He holds it all the time and even got in the bath tub with his frog who he named Cutie!
I will continue to update as I progress, if for nothing else than a memory box for myself. If anyone else is planning on or working through this type of swap and needs some help, I would be happy to provide any help I can!
Old 09-03-2013, 10:28 PM
mklaus1's Avatar
Also, I would REALLY appreciate any input from cam experts or people with experience with a similar sized cam in a similar setup. I am planning on running the 226/230 .598/.601 111 +4 on EPS lobes in the new build. Any predictions on how this cam will perform? I will have longtubes and true dual exhaust. 98 MM Lid and 85 MM MAF or possibly a blade MAF in a 4" tube. Thank you so much!
Matt
Old 09-17-2013, 07:31 PM
mklaus1's Avatar
Default Updates
So I have my LS3 heads and intake now. I have installed dual springs on the LS3 heads and my brother polished the fuel rail for me. I should get my billet aluminum 92mm throttle body and Prothane motor mounts tomorrow. Here are some more pics of the new parts.
Attached Thumbnails LS3 top end swap build thread-ls3-heads-dual-springs.jpg   LS3 top end swap build thread-ls3-valves.jpg   LS3 top end swap build thread-ls3-intake-polished-fuel-rail.jpg
Old 09-17-2013, 08:35 PM
G8RAM's Avatar
I have a 222/226 EPS cam and love it!!!
G8 L/76 making 440 whp / 407 torq.
Very quiet valve train too.....
Old 09-17-2013, 09:01 PM
mklaus1's Avatar
Those are good numbers! Do you happen to have a dyno chart or could you let me know when your cam makes peak power? I have never had the car on a dyno so I am just guessing on shift points now. I usually shift around 6500 but I think I am pretty far past peak at that point. Also, what LSA is your cam and does it have advance ground in? Mine is 111 with +4 so I think that makes it peak pretty early.
Thanks
Old 09-18-2013, 08:21 PM
G8RAM's Avatar
Look under the G8 category of this forum.
Post is DOD Project Complete
I have a couple of dyno sheets posted and I'll have to scan and email you my most recent one. LSA 115 + 3
Old 09-21-2013, 05:57 PM
man-o-war's Avatar
Your 60ft was very slow for the mods you had before. Street tires?
Old 09-21-2013, 06:36 PM
mklaus1's Avatar
If you are asking me then yes, I have never had anything but street tires. I want to try some sticky tires but I have no warm and fuzzies about my stock 10 bolt.
Old 09-21-2013, 07:24 PM
mklaus1's Avatar
Default More updates
I received my billet 92mm throttle body, Prothane motor mounts and injector adapters. The adapters are really nice and fit perfect, they snap into the LS1 harness and LS3 injector perfectly and look like a factory part! The throttle body looks great! I am not sure about sensor outputs and IAC operation but the sensor and IAC bolted on and fit perfectly. I am impressed so far! Pictures attached.
Attached Thumbnails LS3 top end swap build thread-92-open.jpg   LS3 top end swap build thread-92-side.jpg   LS3 top end swap build thread-injector-adapters.jpg   LS3 top end swap build thread-prothane-side.jpg   LS3 top end swap build thread-prothane-top.jpg
Old 09-22-2013, 08:31 PM
G8RAM's Avatar
Yes, street tires on all trips to the track so far.
I think my next mods will be a torque converter, drag radials & trans cooler.
Time to get power to the pavement....LOL
Old 09-22-2013, 10:40 PM
frostopsy's Avatar
Looking good! Good luck with the build!
Old 09-24-2013, 08:55 AM
mklaus1's Avatar
Thank you and thank you for making it possible! I hope you enjoy your new transmission and get the engine torn down and back together quickly!
Old 09-30-2013, 11:10 PM
mklaus1's Avatar
I just got my stainless headers today! Pic attached! I also started to flycut my pistons tonight, hopefully I will have them finished tomorrow, I will upload pics when done. My head gaskets are on the way, Felpro .04 compressed thickness. After that I will get the head milled and then it should be time to start the reinstall!
Old 10-01-2013, 06:25 AM
drillbabydrill's Avatar
Very nice!
Old 10-01-2013, 10:07 AM
mklaus1's Avatar
Originally Posted by drillbabydrill
Very nice!
Thank you! It is taking a lot longer than I anticipated but slow and steady wins the race!
Quick Reply: LS3 top end swap build thread
