cam ideas please help!
Ok I'm looking for a brain for my car. My car will be driven on and off the trailer and at the track. Thats it. I'm gonna be running a l92 converted to ls3 minus the valves. I will have stock heads, stock intake manifold, stock everything minus injectors. Tranny is a th350 with a 4000 stall launching off a transbrake going to 4.30s out of a ford 9". Car is gutted. If you guys were gonna spec out a cam what would you use?
So far I have a response from tsp
Preach.......Hell looking @ your join in date, follow statement above......Listening will save you,more times than not.Try my cam man.....Martin ......@ Tick performance cams, look over to the right where the list of listed performance Dealers are listed and give the guy a call....I can tell you that your cam will be in the 228- 239 intake duration @ .050 range if that helps any.
