LS3 Oversized Valves
I am trying to find one intake valve preferrably 2.2" that will fit in my LS3 heads. I believe the stem size is 8mm. Anyone know where I can buy just one custom sized valve? It doesn't have to be exactly 2.2...2.19 2.21 etc will work. I don't need expensive titanium or lightweight valves either, cheaper the better.
Thanks
Matt
Thanks
Matt
Moderator
That is HIGHLY debatable.
Try Ferrea, PN F6280. They're about $26 each.
Thanks
Matt
Thanks
Matt
Thank you for the help! I am not running the valve, I am going to use it to flycut my pistons. The stock valve is 2.165 so I was looking for a little larger valve to make sure I get the cut wide enough.
