LS4 Turbo
LS4 Turbo
Hello,
Im helping someone building a Turbo LS4, im not an expert when its time to compute datas for camshafts swap...
since its a tc application, i need a cam with less overlap (lobe separation angle) and a lil bit more duration.
so, will a LS9 camshaft will fit in the LS4 block ? what will i need to change ? pulley cover ?
Now, w/ the new camshaft, will i need to change the rockers rations ? i guess yes, can someone gimme the camshaft specs ( camshaft specs only, sometime i see ''lift with rockers ratio'' )
thx guyz
thx guyz
