Getting my ducks in a row- Convert LQ4/9 to 58X
Through searching I have gathered only bits an pieces. Wanted to know if I'm missing anything.
I wan't to swap a LQ4/LQ9 into another car of mine (non Fbody) and convert the motor for 58x to run a newer harness and use the smaller PCM.
Reasons
Reasons
- Wish to mount the pcm behind the dash, its very compact behind the dashboard plus vintage air unit will go behind the dash as well so that makes it even more crowded.
- Wanting to build a ls2 for boost, so while that very slow process develops, and when its complete it will be a simple change over.
- No I do not want to use the conversion box.
- Drill/Tap side of block for Knock sensors
- Swap 58x reluctor wheel onto the 24x crank
- New Crank Sensor
- LS2 timing cover with New Sensor
- Swap in ls2 cam gear
- Plug hole in back of block where the old cam sensor was.
Reasons
Reasons
In other words, you can have the smaller PCM you desire without converting reluctor wheels.
Tipsy
