Morel limited travel preload!!!!?
I am putting some Morel limited travel lifters in my motor and was wondering what the preload should be (aluminum block & heads) also I wanted to know if I can use non adjustable rockers w/ these lifters?
You shimmed the stands to get better rocker geometry? What did you use to shim them? I'm assuming washers, correct?
Im about to check the pushrod length on mine today and I have the Lunati 72532 (morel 5296) in my 416 with stock rockers.
