cam degree help asap
Hey guys. I redoing my cam and timing set. Changed to brian tooley cam and from a single roller to a comp cams part # 7102 billet pre stretched double roller. So I havnt put the lower gear on yet bc im not sure what mark I need to put it on. I been told comp cams (brians grind) there always advanced so im just trying to gwt my pvc right amd put the cam where its specd to perform. Never done this before. Need help asap guys. Please chime in pros. Thanks. If u want pics or to text me. Pm me your number amd we can talk. I need experienced people. Thanks guys
After you degree the cam, if you need to advance or retard it, then you'll have to remove the lower gear and move it to the desired advance or retard keyway.
That's why I prefer the hex-a-just because it doesn't require removing the lower gear, just loosening the cam gear bolts and turning the hex.
