Cam/Stall converter question - 68 C10
I have an L99/6L80 out of a 2013 Camaro SS. I installed it in a 68 C10 SWB:
https://ls1tech.com/forums/conversio...e-tvs1900.html
I mechanically deleted the VVT/AFM basically conveting it to an LS3. While doing that I installed a Comp Cam 219/235 113LSA 3-bolt cam along with dual springs and 7.4 pushrods. I also placed a TVS1900 Magnacharger on top with Siemens SD80 injectors. Now to my question, the 6L80 has the factory stall (2200??), will I need a higher stall, and if so, what size? I'm running a 4.11 gear with a 31" tall tire in a 4000 Lb truck. Thanks in advance.
Cam Specs:
Cam Style: Hydraulic roller tappet Basic Operating
RPM Range: 1,500-6,700
Intake Duration at 050 inch Lift: 219
Exhaust Duration at 050 inch Lift: 235
Duration at 050 inch Lift: 219 int./235 exh.
Advertised Intake Duration: 269
Advertised Exhaust Duration: 285
Advertised Duration: 269 int./285 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.607 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.621 in.
Valve Lift with Factory Rocker Arm Ratio: 0.607 int./0.621 exh.
Lobe Separation (degrees): 113
Camshaft Gear Attachment: 3-bolt Computer-Controlled Compatible: No
Grind Number: 269LRR HR13
Engine Mods:
DOD/VVT mechanically deleted
3 bolt Competion Cam 269LRRHR (219/235 113LSA)
2013 Camaro SS MAF
LS9 MAP
Holley Fuel rails
Siemens SD 80 injectors (http://fuelinjectorconnection.com/sh...?productid=285)
A1000 fuel pump with 10AN feed (8AN to rails/8AN return)
Aeromotive Boost referenced fuel pressure regulator (Set to 58 psi).
1 7/8" mid length headers
rear 02s and CATS deleted
A/C
Tranny Mods:
Stock stall
Shriftersix paddle shifters
4.11 gears
31" tall tires
4000 lb truck
Cam Specs:
Engine Mods:
2013 Camaro SS MAF
LS9 MAP
Holley Fuel rails
A/C
Tranny Mods:
Stock stall
4.11 gears
31" tall tires
4000 lb truck
and I'm having a problem with it pushing pretty hard in gear. So I'm not sure if it's the tune, the converter, or a little bit of both. Is there any particular brand of converter you would recommend?
Rob
Thanks Newschool. I forgot to mention this is going to be my daily driver, so drivability is definitley important. I just got everything installed:
Rob
Rob
That forced induction changes everything. I would not go over 3000 on the stall. 2800rpm might be a good compromise. You are going to have boatloads of torque downlow in the rpm range.
Thanks for all the input guys. I am running it with the factory stall as of right now, the problem I'm having is that it pushes pretty hard when in gear (R or D) when I have my foot on the brake. What I haven't figured out yet, is this because of the stall or the tune...
Thanks! Here's an instagram video:
http://instagram.com/p/hRimAsEnuo/
It idles great in park and neutral (750). But as soon as you put it in gear, it almost seems like you are power braking it....
Yea , that's not coming out with a tune. If it had one of those supercharger high idle issues that some have before a tune, things would be different. The problem probably is that you have very little torque at 750 rpms and the converter is trying to couple. The higher you torque output, the high a given converter will stall. I think it will take a higher stall to be able to idle in gear without the truck trying to move on you. Something between 2500-3000 would work well with your camshaft. I use to run that cam and it came in very early. I ran a 2100 stall with that cam and didn't have any issue with idle in gear. It would move if I let off the brakes, but was easy to hold still.
http://www.circledspecialties.com/p-...converter.aspx
The more expensive one of course, LOL.
So a 2800 stall??
