Dura-Bond cam bearings - Standard CH-23 or Performance CHP-23 ?
Old 01-14-2014, 11:01 AM
FastKat's Avatar
Default Dura-Bond cam bearings - Standard CH-23 or Performance CHP-23 ?
Any experience with either of these?
The description of each doesn't really tell me much. When would you use the standard bearings and when would you want the performance bearings?
Old 01-14-2014, 11:50 AM
87silverbullet's Avatar
I've used the standard ones in the builds I do.
Old 01-14-2014, 12:18 PM
DietCoke's Avatar
performance ones are narrower and chamfered iirc.
Old 01-14-2014, 03:38 PM
Gray86hatch's Avatar
Get the coated ones.
Tim
The following users liked this post:
Homer_Simpson (01-09-2022)
Old 01-14-2014, 03:51 PM
v8pwr's Avatar
The performance ones are coated by Calico and should have a T @ the end of the part #.
Old 01-14-2014, 08:09 PM
FastKat's Avatar
What's the big advantage for the coated ones?
The "performance" Dura-Bond bearings are available coated and uncoated.
Truth is, this is a budget build. Are the standard ones good enough?
Old 01-15-2014, 06:13 PM
v8pwr's Avatar
OK. I forgot that they offered those. What do your cam bearings look like? IIRC the CHP part # has a better bearing material (micro babbitt) for increased loads. The CHP-23 is pretty cheap. I have a NIB set of CHP 10s I'd like to get sell but they're not interchangeable.
Old 01-15-2014, 10:06 PM
FastKat's Avatar
Is there any downside to the performance bearing?
Old 01-15-2014, 10:39 PM
DietCoke's Avatar
The perf ones are used aftermarket cranks, which are usually machined to accomodate the bearing chamfer. Stock cranks, you use regular bearings. In the case of cam bearings, i don't see why it'd matter. I have basic durabonds in my car and it's seen 8k rpms.
Old 01-18-2014, 06:13 PM
v8pwr's Avatar
There isn't a downside to the performance bearings that I know of. They are not chamfered because the camshafts bearing journals don't change when you use an aftermarket cam. This is pretty easy as far as upgrades go.
Old 06-07-2021, 05:34 PM
Ls3Rx7Party's Avatar
Back from the dead. Any difference in these?
Old 06-08-2021, 10:19 AM
pannetron's Avatar
Looking at the Dura Bond website, I found this:
Fluoropolymer Composite Coated Bearings
This dry lubricant actually penetrates the surface where it has been applied. The primary advantage is that bearings with FLUOROPOLYMER Composite Coating retain engine oil on the surface, even under extreme heat and pressure conditions.
Being a lubricant itself, the coating provides secondary (back-up) lubrication in the event that momentary oil starvation occurs. This characteristic is especially important during start-up because oil does not reach all critical components immediately.
They list CH-23 and CH-23T (coated) both as "high performance." I used the CH-23 in my build but would have used the coated bearings if they's been available back then.
The following 4 users liked this post by pannetron:
Corona (06-09-2021), G Atsma (06-08-2021), Homer_Simpson (01-09-2022), Ls3Rx7Party (06-09-2021)
Old 01-08-2022, 03:16 PM
StorminMatt's Avatar
I actually talked to Dura-Bond about this just the other day. It would appear that the difference between CH and CHP bearings is the thickness of the backing material. CHP bearings have a thicker backing material in order to improve the strength of the bearing. Because of this, the CHP bearings have a thinner babbit layer. A thinner babbit layer means less good embeddability if there are contaminants in the oil. This would appear to be the main compromise when using the higher performance CHP bearings vs the CH bearings.
Quick Reply: Dura-Bond cam bearings - Standard CH-23 or Performance CHP-23 ?
