Best ls2 street race cam
Yes I know another one if these "best cam for ls2 threads" I'm sorry but I couldn't find the answers I was looking for
So I picked up a complete lq4 for 400$
And I bought some used ls2 rods and pistons.
I'm looking to make a iron ls2.
I have a few cam choices I've thought about running. Vrx5, vindicator or the ms3
I was wondering which cam would be the best for red light racing and occasional Friday night drag racing. And I'd like to make 450-500 whp, but still make power under the curve as you say.
The motor will be stock internal iron ls2, with a ported ls6 intake, ported and polished 243s that have had a 3 way valve job. I'm going to have compression around 11.5-1 and I play on spraying a 175 wet shot once in a blue moon.
I already have a 3k stall but I will consider going to a 3400-3600 when I got to my 4l80e. And 3.73s in a ford 8.8 rear end
I'm open to suggestions , and advice
You want to contact Martin Smallwood From Tick, Ed Curtis from Flowtech or someone else, to spec you a cam I would go with Martin he will get back to you quickly, and ask a bunch of questions, the more questions they ask usually the better they are. Like what rear gears you have what weight your car is other bolt ons?
Polluter V.2 (239/244 112lsa OR 111lsa)
SNS Stage 3 LS1/LS6 (235/243 111lsa)
SNS Stage 3 LS2 (235/239 112lsa)
I have a few custom grinds in this size range as well.
Depending on driving manners, driving style and where you want the power band will determine the final selection.
i HAVE A LS2 (L76) DOD delete, with LS3 heads and intake, 230/242 duration-605/607 Lift and 113 Lobe Sep. I am running a slightly built 4L80E and put down 416rwhp just to give you an idea of the power a 4L80E robs, it's like a fat girl at an all you can eat buffet, watch out.
LS1Tech Premium Sponsor
Sounds like it will be a fun build. If you want to give us a call we can go over a few possible cam choices with you.
Thanks
Texas Speed
806-698-0365
Thanks
Texas Speed
806-698-0365
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
