Pulling crank without pulling rods and pistons
Old 01-19-2014, 12:22 PM
cwylie's Avatar
Default Pulling crank without pulling rods and pistons
I would like to change my reluctor wheel so I can run a newer ecu. Can the crank be pulled from the bottom and re installed without removing the rods and pistons?
Old 01-19-2014, 12:58 PM
sssalah's Avatar
Yes can be done.
The following users liked this post:
Biebs (03-22-2021)
Old 01-28-2014, 10:53 PM
LLLosingit's Avatar
I would suggest you use Rod Bolt Protectors or at least cut some pieces of rubber hose to fit over your rod bolts before you actually pull the crankshaft out and keep them on until you have the crankshaft back in. They will protect your crank journals from getting nicked by the rod bolts and also protect the threads on the rod bolts.
84ta406 (03-22-2021)
Old 01-28-2014, 11:05 PM
KCS
Moderator
KCS's Avatar
You've never actually pulled an LS engine apart, have you?
The rod bolts in an LS are technically a "capscrew". When the cap comes off, the rods bolts go with it. The older style rods were different, and that's where the protectors are used, not on an LS engine.
Old 01-31-2014, 07:12 PM
LLLosingit's Avatar
Actually I have I just wasn't thinking lol. I've been working on a few traditional small blocks recently.
Old 02-01-2014, 04:06 PM
LSX user's Avatar
Why not just call Lingenfelters and buy a TRG-001 conversion module.
Old 02-01-2014, 05:03 PM
KCS
Moderator
KCS's Avatar
Ah gotcha. There are definitely some SBC processes that still apply, but some stuff doesn't.
Old 02-01-2014, 05:25 PM
cmac06's Avatar
The OP is wanting to run the newer computers compatible with the 58x reluctor. This converts a 58x signal to 24x so that an older ecu can be used on a newer engine.
It'll be tough to get all the rods back on the journals without taking the heads off. I assume if you've got it out, you're at a point where pulling the heads is not that big a deal.
I can see this snowballing into a much bigger project as you dig deeper, though.
Old 02-01-2014, 06:55 PM
KCS
Moderator
KCS's Avatar
It'll be tough to get all the rods back on the journals without taking the heads off. I assume if you've got it out, your at a point where pulling the heads is not that big a deal.
I've actually had to do this one time, it's really not too bad. Just tedious.
Old 02-03-2014, 06:16 PM
iliveonnitro's Avatar
I'm about to swap crankshaft for a different reason (changing 2000 LQ4 to 2001+ to work with a T56.
Is it still difficult to get all the rods back on the journals even though I'm swapping stock crank for stock crank, or is that something specific to the Lingenfelter conversion module?
Old 03-22-2021, 01:53 PM
Ls4brains's Avatar
Default Help
I put a 05 in an 08 thinking it was a 58 tooth like the 08
Do I need to pull engine or is there ways around this
Old 03-22-2021, 09:04 PM
01CamaroSSTx's Avatar
Received 1,785 Likes on 1,293 Posts
Hmmm .. What vehicle are we talking about here?
KCS (03-23-2021)
Old 03-23-2021, 08:21 AM
KCS
Moderator
KCS's Avatar
By the time you tear the engine apart far enough to pull the crank, it's really not much more to pull the engine anyways, so I don't really see the point.
Quick Reply: Pulling crank without pulling rods and pistons
