Harmonic balancer
Harmonic balancer
Does anyone make a basic striped down balancer? I need one to power an alternator and water pump only. Ideally id like one that is light, small and keyed as well as under driven. Oh and a fair price would be nice.
I dont know squat about balancers so point me in the right direction please
Most likely they will suggest you use a stock diameter damper or no more than 10% underdriven with the 66 durometer rubber. Most often ATI will push dampening over an underdriven setup. You will gain more from the better dampening characteristics of their damper then you will with underdriving it.
I wasn't really looking for "results" I need a keyed balancer for the new crankshaft. I'm happy with the way the stocker performed I just don't like the look. Honestly I dot know anything about balancers. What "results" could be had running an ATI vs. Stock or pro products?
