2010 camaro ss 408 swap
Old 01-25-2014, 07:10 AM
js2fst's Avatar
Default 2010 camaro ss 408 swap
I have a iron block 408 24 tooth looking to installing it in a ls3 5th gen. What is needed
Old 01-25-2014, 11:17 AM
FastKat's Avatar
Some sort of converter box to go from 24x to 58x. I know there are boxes to go 58 to 24, nut not 100% sure about going 24 to 58.
Everything else from your existing engine should switch over, including the front cover, intake manifold + fuel system, sensors, wiring, etc.
Old 01-25-2014, 05:51 PM
motion427's Avatar
I agree,seen 58x engine to a 24X ECM,but not 24X engine to 58X ECM.
You might need to replace the 24X wheel to a 58X and add a LS2 timing cover and the 4X cam gear to make it work.
Old 01-25-2014, 07:08 PM
redrocketSS's Avatar
Any reason for going with the iron block? Its much heavier and the 5th Gen is already a heavy car.
Quick Reply: 2010 camaro ss 408 swap
