ls1 to ls2 cam sensor Questions
So Im swapping a 05 gto ls2 into a camaro and have purchased the extension harnesses from tsp. Problem im having is the harness does not clip into the sensor on the timing cover it is completely wrong. Is there 2 different sensors? Does anyone have the part number for the one that I will need for the extension harness to work?
Thanks
Thanks
Does your cover had the short harness like this one http://www.racetronix.biz/itemdesc.a...CSAH-2&eq=&Tp= if not u need this one http://www.racetronix.biz/itemdesc.a...2-CSAH&eq=&Tp=
I just went thru the same ordeal you need the other harness. I used the one that pluged straight to the cam sensor. This is the one i got. http://www.racetronix.biz/itemdesc.a...2-CSAH&eq=&Tp=
