Need Advice on LS3 Turbo build
I got a LS3 with a bad rod bearing. Thinking the crank is bad. So my question is go back with a stock crank? New rods? New pistons? And any advice on a good cam for a turbo. The car just has a STS turbo kit with a 67 mm turbo. So I'm probably looking at max around 750 to 800hp. But will most likely stay at about 650 to 700 hp range bc it is a streetcar. I appreciate any help thanks!!!!
