looking for cam advice forged 6.0 with prc ls3 heads
Old 02-18-2014, 08:45 PM
bigfatls6's Avatar
Default looking for cam advice forged 6.0 with prc ls3 heads
I have forged ly6 6.0 with prc ls3 heads. The valves are the no-hollow stem. Motor should be about 10.5:1 comp. The heads were milled .020and it has 11cc dish wiseco pistons. eagle hbeam rods and stock crank. Im looking for a cam to go with this setup. This will be going into a 92 mustang coupe with a 4l80e. I haven't bought my converter yet so I can still match my conveter to my cam. car will be about 3k lbs and has 373 gear. I will be running a ls3 intake and fast 92mm tb for now. I will also be using a little nitrous.
Any of you guys have experience with a certain cam with a 6.0 and ls3 topend post up results.
Old 02-18-2014, 10:05 PM
bigfatls6's Avatar
Street/strip 1/8th and 1/4 mile
Old 02-19-2014, 05:59 AM
redtan's Avatar
Any reason you went with such low compression?
Old 02-19-2014, 02:14 PM
bigfatls6's Avatar
I bought the short block and heads from a friend. It was set up for his gto with turbo. The short block has 11cc dish wiseco pistons. I may go turbo in the future but for now I just want to get the mustang together and running and iron out all the swap bugs before I tackle a turbo build. So I would like to get a cam picked out that will give me as much power as possible with the compression I have. The heads have been milled .020 to get the compression to 10.5.
Old 02-19-2014, 09:27 PM
LS1Tech Sponsor
COSPEED2's Avatar
We can fix you up with a great custom cam for your build. Keep us in mind!
Quick Reply: looking for cam advice forged 6.0 with prc ls3 heads
