Head gasket selection help needed
I'm running a 4.010 bore with TFS 225's. I'm looking for a .040" head gasket that has a 4.010 bore (or as close as I can get...not smaller obviously).
I'm starting with big dished piston and trying to recover as much compression as I can...I'm told if I mill the heads any more I will be risking intake/bolt alignment issues. Is there anything else I should consider?
You wont gain much by going from .053 to .040. What chamber do you have on the heads and what dish do you have on the piston? I am guessing you bought a boost motor and are trying to run NA on it?
Standard HG size that is available would be a 4.030 x .040.
I bought a already built running n/a car, then decided to change the combo and (while I'm at it) want to get as close to 12:1 as I can get.
The shortblock is by TSP
Diamond -10cc (zero deck)
59cc chamber
The calculator puts me right at 11.70 with a .040x4.030 gasket. Looks like that's bout the best I can do.
59cc chamber
How much Static Compression do you have now and what SCR are you trying to achieve ?
I started at 10.8scr before I decided to swap heads/cam
