LS3 with 6.200 rods?
I snapped the timing chain in my LS3 and now I'm finally going forged. Of all the things to break on the stock bottom end, I didn't expect it to be that. My engine builder recommended doing a 6.200" rod. Are there any other folks here running that rod on a stock stroke? Livernois stage 3 LSA heads going on top with hollow stem intake valves and inconel exhaust valves. 227/243 .619/.600 115+4 Lunati cam. Ti trim Vortech head unit running 10% overdriven.
The build:
Race Tec 4.07 -4cc Pistons w/ tool steel pins
Total Seal AP rings(steel top, napier 2nd)
Molnar 6.200" Rods
ACL Rod Bearings
ACL Main Bearings
Durabond Cam Bearings
Bore
Deck
Balance
Assemble
The build:
Molnar 6.200" Rods
ACL Rod Bearings
ACL Main Bearings
Bore
Deck
Balance
Assemble
The 6.200" Molnar rods are only $569 and the pistons are $730. I thought you could only get the 6.300" in something fancy like the Callies I-beam or Oliver? Randy at Racetec said he would rather modify a stock stroke piston for my needs rather than modify a 4" stroke piston. It will only take a couple of weeks to get the pistons. From what my machine shop told me they average about 2-3 weeks on custom piston orders. I'll probably still be waiting on Vortech to get my blower back to me from the Ti upgrade even after the motor is done.
Moderator
