6.0 truck engine
Old 03-19-2014, 07:35 PM
my64Impala's Avatar
Default 6.0 truck engine
Can I change water pump and all brackets off of GTO to go on 6.0 truck engine.
Old 03-19-2014, 07:45 PM
68BBChevelle's Avatar
Should be able to. You have to run gto balancer too cuz it different from truck.
Old 03-19-2014, 08:01 PM
my64Impala's Avatar
Thanks putting it in a 64 Impala and changed manifold and truck water pump will not work.
Old 03-20-2014, 11:05 AM
george g's Avatar
I have a 6.0 truck block in my gto with the stock accessories.The only thing is 1 of the alternator bracket bolts need to be drilled into the 6.0 block.
Old 03-20-2014, 10:28 PM
Johann Gottlieb's Avatar
The generation IV Vortec 6000, is a V8 truck engine. It is a bored version of the Vortec5300. Displacement is 6.0 L (364 in³) from 101.6 mm bore and 92 mm stroke. It currently comes in two versions, the LY6 and L76. All Gen-IV 6.0L engines feature drive-by wire throttle control and may require the throttle pedal for the engine to run.
Old 03-21-2014, 06:01 AM
my64Impala's Avatar
already have gas petal thanks
Quick Reply: 6.0 truck engine
