Best flowing ls7 heads
Without getting into the whats your purpose bullshit which head is the best flowing.
Best i have found is the mast 305cc ls7
Lift range im comparing is 650 on a 4.125 bore
I guess the next question is does anyone make an LS7 intake port head with any style exhaust port so you need custom headers but you get much better exhaust flow.
So far these are the flow numbers i have:
Brand--------------------------Intake-------Exhaust-----Bore
Lift-----------------------------0.650----------0.650
Mast motorsports LS7------------388-----------247---------4.125
Texas Speed PRC LS7x 285cc-----393-----------241---------4.125
RHS wont tell me as stated in email
Lingenfelter LS7------------------395-----------239---------4.125
+ different flow benches will yield different results.
Well, since the OP didn't mention anything about price. Don't bother with anything already posted, see link below.
http://araoengineering.com/lsx.htm
I would use ANY of the All Pro or the new Brodix heads. They are powerhouses. And you dont need "custom" headers for the LS7 port, they just have a different flange for the D port and the primaries are shaped as such. If the port is too big esp to flow those numbers, you will need a custom set anyway. Also make sure to check on what bore size the heads are flowed, and quite a few are not corrected either.
I'll be updating my build thread tomorrow w/ results!
https://ls1tech.com/forums/generatio...per-liter.html
