prc .675 eht broken valve spring?
I had a misfire in cylinder 1, so i replaced injectors and coil but it still didn't cure the misfire. I took the valve covers off and found out that 1 of the double springs was broken. The springs have roughly 200 miles but i was wondering why did it break so soon? Is this a common issue on these springs? I will be calling Texas Speed & Performance on monday morning to let them know about the situation.
MODS:
Prc 265 heads (unmilled)
pfadt headers/b&b fusion exhaust
TSP LS7R cam
FAST 102 setup
MODS:
TSP LS7R cam
FAST 102 setup
prc 675
Texas Speed and Custom have accommodated me every time by sending me replacements, however if another one goes I will ask them to replace the whole set. Hopefully it's just a bad batch. My pushrods are dead on, everything balance d. Lsx r7 cam. Ported stock ls7 heads, new valves. The works. all machine work done by Texas Speed
hmmm i had EHT .675 springs in mine and never had an issue out of them outa the 4 years of driving the car. I did have a lifter go but springs were fine. Car sees alot of miles too.
Yeah the OEM LS7 heads have a higher installed height if you just install the same parts on them as a regular LSx deal like a 243 or TFS235 etc. so may not be as much pressure as you think. I've had to run -.050 locks from PAC and some shims before to get everything back right as compared to a normal style LSx head.
