Removing Rocker Arms
Dumb question but when removing the rocker arms in preparation for a cam swap, does the engine need to be in any specific position (TDC on a particular cylinder, etc) prior to loosening the rocker arm retaining nuts? Or can you just go down the line and loosen/remove them all?
TIA.
Tipsy
TIA.
Tipsy
I've been through and built many LS motors and never followed those directions. I even worked at the dealer and we didn't use those directions. They are non adjustable rockers so I don't see the need to do that but I can see that service manual says to do so. Oh well, to each their own.
It just makes it easier to get the bolt 'home' with the valves closed when you torque them down. You aren't fighting the valve spring trying to open the valve at the same time you are torquing the bolt. Keeps from getting the rocker cocked and busting something. lol.
You can't accurately torque the bolt against the spring pressure!
Thanks for the replies. My concern was that if each valve is not closed when loosening that respective rocker arm, the bolt could possibly strip or damage the thread because of the spring pressure.
Tipsy
Tipsy
