LQ9 Piston thickness??
In the middle of notching pistons on an assembled motor and I'm at .180 and am still shy of about .040 to feel safe running her... But the junk LS1 piston I have here, I drilled a hole in an measured and found them to be about .250 thick... Does any one know if the flattop LQ9 pistons are as thick? thicker? or thinner?
Spent a good hour searching the forums and can't find a real answer.
Thanks in advance!
Shaun
Thanks in advance!
Shaun
