Can someone verify these clearance numbers for me? Block for turbo.
I'm starting pre-assembly checkouts on my LS2 402 and plastigage'd the mains and rod bearings so far. I got 0.002" on all the rod bearings, I'm good with that. But I also got 0.002" on the center 3 main bearings, and a little bigger (0.0022-0.0025ish)on the front and rear mains. I've heard 0.0025" a lot on the forums for high horsepower builds, and my engine builder recommended 0.003" I used Clevite MS2199H bearings. I'm debating on sending these back and ordering the MS2199HX bearings to get another 0.001" of clearance. Is there a better way of gaining around half a ten thousandth?
Also, I'm using Weisco -20cc pistons. The widest ring gap suggested in the box (for full race application) was 0.0060 x bore (4.005")on the top ring, and 0.0063 x bore (4.005") on the second ring. That gives me 0.024" and 0.025". The recommendation for performance/mild race was more like 0.022" first and 0.023" second. The most this car really see's is test and tune a few times a year. I've seen quite a few threads using quite a bit larger gap, but has anyone had a failure at these factory recommended settings? I'm gonna start the file fitting this afternoon and just wanted to make sure they sounded right.
My goals for this motor are 800-850 rwhp with a turbo (probably 6500 rpm max), so I want to make sure I have enough room. I only have plastigage to work with so measuring in the ten thousandths is beyond what I have. Half a ten thousandth is the best I can do accurately.
Thanks for reading all this and giving feedback
Plastigauge is not the best method for measuring it but..
This is for Coated bearings
Iron block .003-.0035 on mains
Aluminum block .0022-.0025
Rods .0022-.0026
I would use coated bearings for your FI build as you dont know how much the crank whatever it is will flex
Rods .0022-.0026
Well.. I ordered a decent .0001 mic and some telescoping t-bore gauges and re-measured everything 3x per journal. Here were my averages.
Journal 1
0.0015-0.0017"
Journal 2
0.0015-0.0016"
Journal 3
0.0017-0.0018"
Journal 4
0.0018-0.0019"
Journal 5
0.0018-0.0021"
At this point, I guess I'll go ahead and order some undersized bearings and try again.
There shouldn't be any issues mixing and matching between a standard and a 0.001" undersize set should there?
I tell ya, the way this budget on this engine refresh is running away, I'll be amazed if I have anything left for turbo parts lol. Always one more $200 item in line. I'm really starting to understand the whole "throw in a junkyard motor and run it til it blows" approach.
Journal 1
0.0015-0.0017"
Journal 2
0.0015-0.0016"
Journal 3
0.0017-0.0018"
Journal 4
0.0018-0.0019"
Journal 5
0.0018-0.0021"
Yeah. I know the light wallet feeling too. Always something. lol.
From everything I have read on here there is no problem mixing bearings to get your specs right. I read just last week here a guy mixing undersized halves with std half bearings to get it right on the money. Ill be doing the same thing soon.
you don't want undersized main bearings...your clearances are fine right now. If anything get a +001 set and use one shell from that set to give you another .0005 if you want to open them up
