engine running problem
Hi All
Just recently got an LS 3 in a 67 Firebird, Posted on Street Outlaws as July cover car in Canada ( not sure if that matters but you can view it if you like )
Engine is a mild build with better head and cam and a 92 mm TBC.
I have had it tuned and for the most part happy.I have put 300km / 160 miles on it
I recently left the ignition key on with out the engine running for about an hour by mistake. Now the problem
The engine fires up but quits just as quick, as if it was not getting fuel but I am showing 60 lb on the pressure meter for fuel. It primes no problem and fires on 2nd turn of motor
The computer in it is out of a 2002 Camero and I am leaning to believe that somehow the computer has defaulted into an anti theft mode. I have disconnected the battery for 12 hours and reconnected it thinking it would erase any retained crap but continue to have same problem.
Any suggestions or do I need to have Howell Racing reprogram computer again?
Help Please
Help Please
Trying 2 think of who would I call if I had that problem. 1st hit Howell and ask what maybe the problem and how 2 reset it correctly... but I would call LME,LMR,510 Race Engineering,or Fastlane.. all in Houston..
also Go make a friend @ your local GM service dept. helps.
when they overwrote the stock computer for the 6.2 liter engine
