Best oil to use with big cam?
Location: Coast of San Mateo County Between Pacifica & HMB
Amsoil Z-Rod 10w-30 has 1300 PPM Zinc & Phosphorus plus antic corrosion
And rust inhibitors for when it sits in cold weather along with very
High anti shear properties still has detergents in it, not a race oil per say and with
1300 PPM. zinc & Phosphorus may not be best for cats depending on oil
Consumption if any. 6 mos or 3-5k drain interval depending on nitrous
Boost or methanol usage.
Thanks for the comments. After researching and reading forums, I think I'm going to try the Gibbs LS30. The motor is a bit louder after the cam install and running hotter with the ARH LT's , so maybe this will help. I'm currently using the Mobil 1 full synthetic 10W-30. Not too sure what filter I will pair it with. Possibly RP...
