LSX block rear cover seal?
Old 08-08-2014, 06:54 PM
6togo's Avatar
Default LSX block rear cover seal?
I just noticed the other day that the rear cover seal for my LSX block is a thin rubber string which goes in a groove on the cover should that be installed dry and should i glue it to the cover first before installing so it dont fall off when installing?
Old 08-08-2014, 07:10 PM
Ari G's Avatar
Yes its good to use light grease to make it stick in the groove and install it with the block off the engine stand
If you are re using a old one,make sure its still good,if it dose not stick past the groove when installed,its time to get a new one
Old 08-08-2014, 08:27 PM
6togo's Avatar
No its all brand new! also while were in the subject does the front and rear crank seals get installed dry?
Old 08-09-2014, 01:09 AM
CAMSTER's Avatar
Critical high pressure area, the two engine side are connected around the rear and sees full pressure, in my case 73 plus psi @ wide open throttle.
I use light silicon in the groove to be sure it will hold seal and stay in place no matter what.
Old 08-09-2014, 01:14 AM
CAMSTER's Avatar
GM manual says dry I like to put a minimal light oil film on crank, has worked for me.
Quick Reply: LSX block rear cover seal?
