07 silverado 5.3 afm delete
Old 08-30-2014, 01:55 PM
frustratedwth5.3's Avatar
Default 07 silverado 5.3 afm delete
Recently developed a misfire on # 6 cyl, after tearing engine down found intake lifter stuck in closed position. I replaced all lifters with LS7 lifters, tapped & plugged oil ports for afm in the valley & reassembled engine, had engine tuned & AFM disabled. Ran the engine & had a code for random misfire come active at idle. Yep I shoulda done more research before putting it back together. Can anyone recommend a good cam to install, this is a daily driver so nothing really radical, maybe just a little hotter than stock that I can use the same heads & pushrods with.
Old 08-30-2014, 08:21 PM
2xLS1's Avatar
This is the 2014+ Gen V Internal Engine forum. You will have better luck asking here.
http://www.performancetrucks.net/forums/
Old 09-19-2014, 09:20 AM
MuhThugga's Avatar
I haven't torn my 5.3 apart yet, but I'm just stabbing a stock LS2 cam I have laying around in there when I take all the AFM crap out.
Quick Reply: 07 silverado 5.3 afm delete
