Dry sump benifits
Old 09-16-2014, 12:58 PM
allblowdup's Avatar
Default Dry sump benifits
I am aware of the standard benifits by going with a dry sump system. My question is, does it tend to make a bigger difference depending on the stroke of the engine at the saem rpm range (6000 rpm). 3.622 vs 4.125 LSX block specifically.
BBC have a real hard time just living without a dry sump or real good pan and 4.5" stroke cranks. Surface bearing speeds are high and any air getting in the system seems to cause issues.
Old 09-17-2014, 06:32 PM
LLLosingit's Avatar
I'm not an expert by any means but that would depend on the oil pan you are able to run in your chassis. If you can run a deep pan and aren't running cornering with high grip tires (slicks) then you shouldn't need a dry sump. There are several companies out there that make baffles like http://www.improvedracing.com/baffle...ffle-p-30.html
Dry sump systems allow better oil control, Greater chassis clearance/ground clearance, More capacity, filtration/ cooler oil.
Quick Reply: Dry sump benifits
