10s M6 N/A combos wanted....
#41
https://ls1tech.com/forums/dynamometer-results-comparisons/1372582-402-afr-205-s.html
Figure I'll share the old deadly combination.
#42
Anybody else want to share........ I know it's some more out ferocious combos out there. Let's hear and kick off 2015 right !!
#45
Good grief!! Vette sounds like it's all business!!
#47
Lol yeah I do believe I showed you some pictures, theres a few pics of it in the drag racing results section. Still impressive though bc you used mostly shelf parts that are affordable instead of spending abunch on that high dollar stuff. You have a well thought out car that works.
#53
Awesome!! That 404 is set on kill mode. Is the heads ported ? The cam specs are surprising with the large split on a cathedral head but it's definitely working.
#54
I bought the cam originally to use in the stock LS1, but ran into problems where I didn't have enough piston to valve clearance due to stretched valves. Don't see that very often... So I decided to just buy a forged short block. The heads are out of the box from GMPP that are cnc ported. I found out later that GM had Lingenfelter port all their heads for a while, so that's who ported these.
#55
395ci LS1 (3.915 x 4.100)
Livernois Stage 3 LS6 heads
Cam Motion 231/239 .628/.637 112 LSA
FAST 90 (mamofied)
4.10 gears w/ 28x11.50 Hoosier QTP
Stage 3 T56
Raceweight ~ 3550lbs
10.81 @ 129mph (better driving would have netted me another tenth or so)
The key is to get the power to the ground for the first 330ft and drive it like you stole it
FAST 90 (mamofied)
Stage 3 T56
#56
FAST 90 (mamofied)
Stage 3 T56
FAST 90 (mamofied)
Stage 3 T56
Awesome time!! Rwhp? 3550 is where I want to be on weight. Not too light but not too heavy either
#58
