Oil pump alignment
Oil pump alignment
My oil pump is installed aligned from the builder however i need to remove it so i can install the dampener can the pump be reinstalled without being disassembled properly?
When I installed my pump I used the Oil Pump Alignit tool from sac city corvette, and it worked like a charm...are you sure you need to pull the pump to get the dampener in there though?
Edit: just went back and looked at the pics of my oil pump install and you definitely need to pull the pump to get the dampener in there...please ignore my previous comment...
Yea I was hoping to install without removing the pump but its to tight! I was a bit Leary of the Sac tool because it says in the comments you should still check it with feeler gauges or something to that effect. I have their other tools already which seem like they will do a good job but that's not as critical as the pump!
