Aggressive cam lobes?
Most people here want aggressive cam lobes. Why? Because someone told them they are better. So what is an aggressive cam lobe? To take the most advantage of the LS Chevy engine design the cam lobe must be smooth and stable. Generally in this LS Chevy engine, the smoother and more stable the cam lobe, the more power and RPM capability the engine will have. So generally the less aggressive lobe will make for the most aggressive (powerful) engine.
There is no need in having 8 different lobe styles or variations for the LS Chevy hydraulic cams. Most of the engine combinations I see on here run from idle to 6500 RPM with a valve lift from .550” to .650” lift and with spring seat pressure 130lbs to155lbs with 350lbs to 400lbs open pressure. The measurable differences in these lobes are very slight, the real difference is that some of them operate very well and others do not. The “hard” or “aggressive” lobes may make a small amount more vacuum at idle and may show a two pound gain in torque at 4000RPM but will cause more valve noise and float the valves sooner plus having a destructive affect on valve train parts and valve seat sealing. The “softer” lobes will have a little less vacuum at idle but provide quite valve train operation and extend the valve “float” RPM 300-500 RPM and do not destroy valve train components.
What do you call “aggressive? Is it high acceleration or high velocity? Quick ramps? Which is harder on the valve train? The cam with higher lifter acceleration rates will be harder on the valve train.
Let us compare technical data on two lobes both with 230 degrees duration at .050” with .350” lobe lift. One lobe we’ll call “hard” the other “soft” even though I don’t like to use the word “soft”, but it is soft compared to the hard lobe. I prefer to call it the correct lobe for your engine.
Compare:
HARD SOFT
MAX ACCELERATION: .00037 .000323
MAX VELOCITY: .0073 .00775
NOSE ACCELERATION: - .00023 - .000212
So which one is more “aggressive”? The soft one moves the valve FASTER or higher speed. So what is aggressive? One of the reasons the hard lobe floats the valve sooner is because it has higher “nose” acceleration, which is negative acceleration at the top of the lobe.
Compare:
HARD SOFT
