15k engine build decision????
Old 10-18-2014, 08:49 AM
Tuskyz28's Avatar
Default 15k engine build decision????
Hey I'm fortunate enough to make decent money at my job. I'm wanting to buy-build a motor I can drive hours on the freeway problem free but run 10s if needed. If you had 15k budget what will you buy-build engine wise naturally aspirated ?
Old 10-18-2014, 10:43 AM
Mercier's Avatar
What vehicle? Transmission requirement? Emissions requirements?
Old 10-18-2014, 02:05 PM
LPE 403's Avatar
You building or having it built?
Old 10-18-2014, 02:20 PM
Tuskyz28's Avatar
Having it built. Car is a Camaro 6 speed z28. Brent is me Jermaine as in baconz28. ;-)
Old 10-18-2014, 02:55 PM
GSAWYERS's Avatar
You can get a good 427 shortblock from Livernois, good heads and get a cam spec'd. It's possible to hit your goals, the little things and labor will eat money quick. You'll need a good tuner and a competent shop to do the work. At least you have a realistic budget...
Old 10-18-2014, 04:06 PM
Mercier's Avatar
For that kind of budget you could consider a drop-in blown LS3 setup from Chevy. Talk about hours of idling in traffic reliability. It would blow most or all of your budget but wouldn't have to turn a wrench on it for 50,000+ miles.
I know you said NA but I think it's worth considering..factory supercharged setups drive like a Honda in traffic and like a ******* rocket ship when you get into the gas.
Old 10-18-2014, 05:01 PM
99creelz's Avatar
Buy a 454 lsx crate motor and have the heads ported maybe change the cam and you might be there.
Old 10-18-2014, 05:53 PM
Hi-Po's Avatar
I couldn't see spending 15k on a NA engine, unless trying to go all out and squeeze the HP out of it.
If you're paying someone to remove/install, that will eat up a sizeable amount.
Old 10-18-2014, 07:24 PM
M.BOZZ's Avatar
Someone on here is selling a 454 lsx gm engine ( used ) I think 9, 500 bucks.
Old 10-18-2014, 08:19 PM
Briou's Avatar
Check out my build...about the same budget if you neglect my intake...ERL short block, Frankenestein heads, and a Mast intake would make awesome power for 15k...but that doesn't include any sort of labor for my build...
Old 10-19-2014, 12:25 AM
Tuskyz28's Avatar
I really want go aluminum to keep weight off the car... With that being said I have thought about a ERL 440ci with a good pair of heads from Chris Frank and a custom cam ( I got a buddie with a ERL block right now 4.140 bore 4 bolt Super deck 1 for less than 3 grand)
Option 2 I have considered is buying a LS7 and doing a stealth cam upgrade ( a cam that improves power but sounds like a stock LS1)
Option 3 I have considered in my mind is doing a "big bull" motor from SPDC... a lot to think about tho
Old 10-19-2014, 08:40 AM
LPE 403's Avatar
Hey man! Just buy mine!! Might be a little north of 15 but it's already broke in, the combo works, 400mi on it, very stealthy, you'll just have to sacrifice the wipers to make it fit.....
Old 10-19-2014, 09:09 AM
Tuskyz28's Avatar
I'm go hit you up on Facebook
Quick Reply: 15k engine build decision????
