Solid roller valve spring help needed
Old 10-27-2014, 07:56 PM
Violence.z06's Avatar
Default Solid roller valve spring help needed
Looking for advice on valve springs for this cam. Been looking at a few different spring sets and ive come down to these. unsure of the spring pressures with the rpm i am after. engine will see 9000-9500rpm. Bottom end will consist of
Custom aluminum rods 6.5375 inch long
cp pistons 1.110 c/h, 4.185 bore
Callies magnum xl 3.185 stroke crank. 38# weight.
LSX block
dry sump and so on and so on
http://www.jegs.com/i/Manley/660/221456-16/10002/-1
cam card for the cam is the following. will be going in a big bore high rpm 350 cubic inch engine. isky ez roll lifters, shaft rockers.
Old 10-28-2014, 08:25 AM
TurboBuick6's Avatar
Need to know installed height and valve pocket OD.
Old 10-28-2014, 10:17 AM
Installed height can be whatever. Dont have the heads yet but i will be using rhs pro elite bare castings ported to fit this motor. Really can go wherever i want with springs that will fit the castings
Old 10-28-2014, 10:25 AM
I Would think about running a PAC-1324 (1.625") or a PAC-1326 (1.550") spring. Will need installed heights of 1.97-2.02"
Old 10-28-2014, 10:31 AM
Any opinion on the nextek springs? Ive heard guys have real good sucess with them. Gain some longeviety also
also seems both those pac springs will coil bind.
Old 10-28-2014, 10:48 AM
I am sorry I miss read you intake lift. The 1324 will work at 2.00". Another option would be the PAC-1330 @2.050.
Do you really want my opinion on Nextek springs??? I work for PAC BTW LOL.
Old 10-28-2014, 10:54 AM
Im open for all opinions. Id rather hear it real from someone who works i the industry then internet fan posts.
also is it possible to find something to work with 1.8 rocker ratio. Forgot to add that part.
Old 10-28-2014, 11:02 AM
Whit a 1.8 RR you will be at .895 lift. if you are wanting to go that much, I would run a PAC-1329 at 2.100"
Old 10-28-2014, 11:30 AM
v8pwr's Avatar
I think NexTek springs are made by PSI. I have a solid roller and went with PAC. My application is a tight lash solid roller for the street and I want it to last. I've used NexTek springs and they are good but this time I went with PAC. The cam specs seem a odd for a high rpm short stroke app. I also recommend that you verify that the lifter's oil band doesn't come out of the oil gallery. You have nearly a 1/2" lobe lift. Those are some aggressive lobes and you will need some serious springs. Tell us more about your cylinder head/valvetrain setup.
Old 10-28-2014, 11:45 AM
Nextek are not PSI, their high end circle track stuff is.
Old 10-28-2014, 12:09 PM
Heads really wont be to special. Rhs pro elite bare castings ported to match my setup. My porter says he can give me 440cfm if i want it but i wont need it. Will use jesel shaft rockers, ti valves and retainers, lash caps, 1/2 inch pushrods. Just stout and light. Top that with a efi single plane and a accufab 6500 throttle body on a 4500 flange.
thats the plan as of right now anyways.
Quick Reply: Solid roller valve spring help needed
