Valve spring ?
Valve spring ?
I have Manley nextek springs #221436-16 currently on my heads which are rated to .660 lift my Hyd. roller is .640/.630 on a FI build is that to close or should i move up to the manley's that are rated to .700?
Just chatted with Manley and he said adjust the height to around .050-.060 coil bind at my max lift and the springs should be fine he did not feel I need to go to a heavier spring so what to do!
