Heads and cam confusion!
Hello guys just need some input and actually confused about a couple of things. I have prc 227 heads ms4 cam with ls7 lifters and a 370 with -2 diamond pistons. I am having some confusion on getting the pushrod length correct. I have the comp checker and I get 12.5 turns until zero lash on intake side but then on exhaust side I am coming up with 12 turns. I am certain I am at TDC and have tried this on differnet cylinders and comes out the same or maybe this is normal not sure. Any input would be great. Thanks
Call Texas speed.... If not somebody that knows valvetrain like Brian Tooley. I would reach out to him first since he is not that hard to get in touch with.
Moderator
Second, how are you getting 12 turns? You should be starting at zero lash and counting the turns until the rocker seats on the stand and the bolt gets tight.
