853 ported vs 799 heads
Old 11-18-2014, 10:07 PM
turbo98z's Avatar
Default 853 ported vs 799 heads
So I have 2 sets of heads and am new to ls1 engines. 1st pair ported 853 2nd 799 stock heads. The application I'm using them for will be a forged 5.7 stock bore with a turbo and cam. So my question is what heads are better or pros and cons...
Old 11-19-2014, 09:23 AM
KCS
Moderator
KCS's Avatar
I'd lean towards the 853 heads. Depending on the piston, you may actually be able to use the larger chambers to your advantage since you're using a turbo.
Old 11-19-2014, 10:30 AM
redtan's Avatar
799s better chamber & port design plus the chamber is a few CCs smaller, same as 243s.
You can't say that the 799s have better chamber and port design without seeing and knowing who ported the other heads. Many times, a good porter can transform and improve the design of the head to perform better than the factory cast.
So depending who ported the 853s, I personally would tend to lean to those. If it's a professional CNCer (TEA, AI, WCCH, Livernois, TSP etc.) then for sure as those are quality programs. If they were done by some random guy in his shed with a dremel I would steer away and go with the proven OEM design of the 799s.
Old 11-20-2014, 10:39 AM
dogsballs's Avatar
Will 853 even fit on a 5.7? Usually no
Old 11-20-2014, 11:12 AM
KCS
Moderator
KCS's Avatar
853's came on stock LS1's, so yeah, they fit.
You must be thinking of 823's. Those are L92 style heads.
Old 11-20-2014, 08:25 PM
dogsballs's Avatar
lol, ignore my half asleep post.
Old 11-21-2014, 09:53 PM
turbo98z's Avatar
Thank you guys. I don't know who ported the heads but it doesn't look like a machine did it lol
Quick Reply: 853 ported vs 799 heads
